1984 300 cd cooling problem
Old Sep 18, 2004 | 07:12 PM
marangio's Avatar
300 cd
Unhappy 1984 300 cd cooling problem
hello, i own a 1984 300 cd and the temp is going way past 100c. when i turn the a/c on the aux fan turns on the way it should. when the a/c is off the fan never comes on. i have checked the fuses, and also grounded the single wire that goes to the sender above the thermostat housing. this single black wire has juice when tested with a test light. is this normal? any ideas? thanks for any help?
Old Sep 18, 2004 | 07:32 PM
moa4r's Avatar
S4
the thermostat itself may be bad, or check ur radiator, try flushing it or replacing it;
Old Sep 18, 2004 | 07:34 PM
marangio's Avatar
300 cd
1984 300cd
hi, new thermostat installed last week. the fan should still come on correct?
