Where is the fuel filter on a 2002 C240?
Old Sep 21, 2004 | 09:20 AM
wizkid's Avatar
Ford Pinto
Where might I find that devil?
Any guesstamation on how long it takes to change it?
Thanks,
Eric
www.installuniversity.com
Old Sep 21, 2004 | 07:32 PM
saturnstyl's Avatar
Its in the rear, under a plastic cover. I think the drivers side.... A few 10mm plastic nuts hold the cover on. Fuel filter has same clamps as the fuel pump lines, so you will need 3 new ones. Pay attention to orientation and which lines go where. You may wish to clamp off the larger line, it tends to dump a lot of fuel. Depressurize too. Also the lines will be stuck on like glue, use a large screwdriver and some paitience to get them off. One of the lines does not have and does not need a hose clamp. Have fun.....
