Maybach S680 Lane Assist
Old Jan 16, 2022 | 01:54 PM
Mbc680's Avatar
Maybach S680
Dear members,
I am looking for a solution to turn off the lane assist permanent.
Whenever i turn off the car and start again it turns on automatically.
I already contacted the dealership but they explained that this is a safety option, and thats why they can’t turn it off.
Even if they wanted to do it there is no ‘progamm’ to use.
The vehicle is a Mercedes Maybach S680 2022.
Old Jan 16, 2022 | 02:32 PM
chassis's Avatar
2017 GLE350 4MATIC
Welcome! Please post a photo of the Maybach.
What you ask likely requires coding. A dealer will not do this as you mentioned. Other specialists can help, but it would likely result in a voided warranty if/when the dealer discovers coding during normal servicing.
Also try posting the question in the W223 section where more owners will see it.
Old Jan 17, 2022 | 03:18 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
loose the lane keeper....
Have you tried using the iCluster settings menu to disable your "Lane Assistant"?
Some people like this option, most driver hate how it grabs the steering wheel and snaps on the brakes.
Old Jan 17, 2022 | 09:05 AM
streborx's Avatar
Top Answer: 1
G550
This "feature" and the ECO Start/Stop were my greatest annoyances with my '19 G550. The ECO Start/Stop was easily defeated by disconnecting the battery charge sensor at its negative terminal. The Lane Assist required removing the switch cluster module (the G550's is just above the headlight control), and adding a microcontroller circuit that creates a button press for 3 seconds each time the truck is started. I made this modification about 2 years ago and it has worked perfectly. I did the same mod for another G owner, but it requires removing the switch module. PM me for more info.
Old Jan 17, 2022 | 09:39 AM
ALFAitalia's Avatar
Alfa 159
That's pretty clever thinking!
