Source for 300SD injector tool (toothed socket)
Old Oct 2, 2004 | 09:46 PM
300SDTURBOS's Avatar
99 E300 TD, F350&ExcurDiesels
Question Source for 300SD injector tool (toothed socket)
All:
What is a good source/part number for a tool to tighten the injectors on my 300SD diesels?
Looks like I need something akin to a "2-tooth" socket to tighten the injector. I have a very slight seep at base of a couple of injectors.
Thanks for the help.
DRG
Old Oct 3, 2004 | 11:35 AM
orcberg's Avatar
I believe the tool you're looking for is Snap-On part# S6104B. It's like $30. 1/2" drive, 12-point 27mm socket. It's used for MB and VW diesels.
Old Oct 8, 2004 | 06:27 PM
2-slot/2-tooth sleeve tool
ORCBERG:
Thanks. The 12-point looks this looks OK for the injector body however, there is a two-slot/two-tooth threaded sleeve in the head that the injector screws into. I assume there is a special tool for that too. The 12-pt is only for the injector/body.
Any other suggestions? Thanks
DRG
