S500 brake replacement instructions
Old Oct 27, 2004 | 11:22 AM
Crankin's Avatar
2000 S500 Brilliant Silver, 1990 BMW 735iL, 1971 Pontiac Trans Am 455 HO, 1976 Pontiac Formula 400
I just ordered parts to replace front rotors and pads, along with back pqads on my 2000 S500.
Are there instructions or helpful hints available here, or anywhere on the net, to make sure I do it right?
Old Oct 29, 2004 | 08:15 PM
redcoupe's Avatar
11 ML350
Tools:
17mm socket
small punch
channel locks
small pry bar
hammer
30mm torx
18mm or 19mm shallow socket.
ratchet
Removed the wheels, knock out the pins holding in the pads, use the channel locks to press the pads back.
Remove the pads.
Turn the wheel, removed the 18 or 19mm bolts holding the caliper on.
Move the caliper to the side(hold it up with a coat hanger).
Use the 30mm torx to removed teh screw holding the rotor on.
And smack the **** out of the old rotor,
Reinstall in reverse order, with new rotors and pads.
(something like that)
Have fun
Old Oct 29, 2004 | 10:36 PM
saturnstyl's Avatar
Have fun
Sometimes thats the only stress relief we get at work!
Old Oct 30, 2004 | 08:44 PM
redcoupe's Avatar
11 ML350
Yes it is.
Old Nov 1, 2004 | 09:01 AM
Crankin's Avatar
Thanks for the info. I will attack this project this coming weekend.
