Antifreeze questions
Not sure how many miles since the last antifreeze change, my cosuin who had it for 6,000 miles says he never changed it so atleast over 7,000 miles since the last... how often should it be changed?
Does it need to be done by the dealer (because I hate going to the dealer already).
The anti-freeze looks clear to me.
What color is your antifreeze now? It should be amber-colored. It should be changed every 2-3 years. You should probably change it now (and other fluids) so you have a reference point for future maintenance.
Whether YOU can do it depends on your expertise and comfort level when it comes to working on cars. If you can change a thermostat, I'd say you are able to flush and fill the cooling system.
This is the method I use to replace coolant for every car I own:
- Remove thermostat, reinstall thermostat housing and hoses.
- Disconnect upper radiator hose at radiator.
- Open radiator drainkock (and on MB engines, the block drains).
- Drain coolant, dispose of properly.
- Siphon overflow tank.
- Run water through the cooling system with the garden hose through the upper radiator hose, until water comes out clear. Flush out overflow tank.
- Drain as much water from the cooling system as possible.
- Reinstall thermostat, button everything back up.
- Find the specified cooling system capacity for your vehicle. Fill 50% of the capacity with pure antifreeze. Top the rest off with distilled or demineralized water.
- Keep topping off the coolant after every warmup/cooldown cycle until the system can take no more.
- You're done!
There are many more fine points to performing this procedure, but the steps above should get you through a quality shadetree flush & fill.
Only Zerex G 05 or dealer-supplied antifreeze should be used. Antifreeze is attractive and poisonous to household pets. Keep them indoors until you finish this job and wash away any spillage.
Here's a link to MB Approved Service Products
He changed the filter (part #1289) and put 7 Quarts of 10W-50 oil (not sure what brand)... all the parts price was $4.20 is that about right? Just want to make sure they did a good job because I just bought the car and need to find a good mechanic
-- Also about how long does an oil and filter change take, it took them a total of 50 minutes... is that about right?
He said all the fluids were ok, but should I go ahead and have them drain the antifreeze and fill up with a certain kind??
Lee
FYI - I live in St. Louis MO, gets kind of cold here!
You can't tell the age of the antifreeze just by looking at it. The same goes for brake fluid, which per specification should be changed every two years.
Don't use the green stuff when servicing the cooling system. Have the shop use Zerex G 05. Buy two gallons and present it to the mechanic when you want the service done.
"You can't tell the age of the antifreeze just by looking at it. The same goes for brake fluid, which per specification should be changed every two years."
-- Would I be best to have them drain the antifreeze and put the kind in you suggested? I know mercedes also sells a brand or is this brand better... remember my car is a diesel, not sure if that matters
It would also be good to change out the fluids just so you have a starting point for future maintenance. After all, you don't know if the fluids have been recently changed or if they're four or more years old. I (and others) do this with every used car I buy. More often than not, used cars are neglected with respect to maintenance than properly maintained, unless you actually know and trust the previous owner.
If the oil looks clean, then you're okay. 10W-50 is an odd grade of oil per my tastes -- too wide of a spread. Consensus among the MB diesel crowd is they typically use Rotella 15W-40 oil, perhaps a lighter grade during the cold winter months.
I think im going to take it to another mechanic and have him change the oil, antifreeze, and brake fluid...
Ill ask him to save the old filter so I know mine was changed.
What type of oil you think I should use?
What type of antifreeze you think I should use?
What type of brake fluid should I use?
-- again my car is a 92 300 D Diesel
-- Would the mechanic let me purchase the antifreeze and oil so I know Im getting the right stuff or should I just tell them the type I want put in?
Use Zerex G 05 antifreeze or buy it from the dealer.
Any brake fluid that meets DOT 4 requirements should be okay.
Flushing out the ps fluid is always a good idea. I use 30,000 mile intervals or anytime the fluid looks dark. Use fluid specially made for power steering as opposed to Dexron atf.
Also am I able to purchase the antifreeze/oil and give to them to put in?
Check your oil. Is it clear or is it black? This should tell you whether the oil needs to be changed.
