Intake and Exhaust cam adjusters on Bank one are not adjusting
Old Aug 1, 2023 | 09:29 PM
PD216's Avatar
R350
So, I've been fooling around with this for a long time on my 2009 R350, 3.5L.
Actually had both cam adjusters replaced as I thought they were hanging up. Today I am looking at live data on my Launch x431 and I notice that neither of the adjusters on the right side (bank one) are adjusting at all.... while the left bank is adjusting as the car runs. I can see that the intake is at 36 degrees and the exhaust is at 20.... and they stay there without movement.
Is this potentially a wiring problem?
I am also experiencing the intake flap issue which I plan to get to soon enough too... but could they be related.
I had a shop install the new adjusters and he said the code came back and it has to be the balance shaft sprocket but I inspected both sprockets with a bore scope and they both look pretty damned good to me. He insists that they must have enough wear between the teeth to be causing the fault code... but I think (hope) it is something different.
Could they have maladjusted the timing alignment on bank 1 causing the adjusters to stick to one position? I suppose I can pull the sensors and see if everything lines up correctly at 305 degrees.
Would love any experienced thoughts on this before I dig in too deep. I am fairly mechanically adapt but since an accident a few years ago, I have to leave some of the bigger projects (especially crawling around under cars) to someone else.
I added a few pics below. One of the tensioner, one of the upper sprocket, and one of the lower sprocket.
Old Aug 3, 2023 | 05:57 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
Making progress ....
Scan the whole car modules with your Launch tool. Your new timing gear should self-adjust.... why it doesn't move calls for an active fault.
I'd keep out of that shop that can ring up parts without finishing the job. Find a MB specialist who will have access to MB repair procedures to align the timing marks.
Old Aug 6, 2023 | 03:27 PM
PD216's Avatar
R350
Can you explain a bit more about what you are saying?
