check engine light on, what next?
Old Nov 1, 2004 | 01:42 PM
c280rookie's Avatar
hi guys
i need your help with my 96 c280.
i have searched this forum and have read a lot of things pertaining to the cel coming on. but i want to be sure, so i am posting my own problem.
i replaced the MAF and the OVP about a month or so ago, and it was running okay.
yesterday i was driving when it suddenly seem to be hestitating, and a very slow pickup. the engine sounded a bit harsh and unhealthy too. then the check engine light came on.
what could be the next likely problem now?
also, i need some advice on what brand of obd scanner should i get. i think i will be needing a scanner pretty much with this benz.
thanks in advance.
Old Nov 1, 2004 | 06:12 PM
saturnstyl's Avatar
Plugs, wires, resistor tips, and coils. Sounds like a good old fashioned 104 ignition system failure so far.... Get some fault codes and let us know.
Old Nov 3, 2004 | 03:04 PM
redcoupe's Avatar
11 ML350
Did you repaced the MAF sensor or did you have a shop do it?
Becasue if you did it the selfadaptaions were not reset.
Might just need the selfadpations to be reset.
Old Nov 5, 2004 | 03:16 PM
c280rookie's Avatar
hi guys
got my car back last night, and my mechanic told me that the car had a cylinder misfire, and he changed all the plugs and the ignition coil(s). how many are the coils anyway?
car's running great once again.
thanks for your inputs and have a good weekend.
Old Nov 5, 2004 | 09:23 PM
saturnstyl's Avatar
3 coils. Each coil fires 2 cylinders. I hope he did the plug wires and tips also..... Otherwise you could very well be visiting your mechanic again in the near future.
Old Nov 7, 2004 | 04:40 PM
c280rookie's Avatar
Hi guys,
I asked my mechanic about what was actually replaced. He said he replaced one coil and wires. He inspected the plugs, and told me that these are fairly new, so no need to replace them.
The car's running very well once again.
