CLK 200 Kompressor (M271 1.8L) Running rich and high CO emission
Old Aug 23, 2023 | 11:11 PM
Andre1234's Avatar
CLK 200 Kompressor 2003
Hi!
My car recently failed a emissions test because of too high CO. The car seems to be running rich too. I have not noticed the car running worse/rough or smell from exhaust but fuel consumption feels exsessive. The car is throwing the following DTC codes: P0170, P0137, P0172, P0138, P0136, P0141. The P0170 (Fuel Trim Bank 1) and P0172 (System Too Rich) seem to be the ones that return when cleared. It seems the bank 1 sensor 2 is just throwing codes at random and they dont immediatly return. I have changed both o2 sensors about a year ago along with the vacuum line under the air box. I checked the connection box on downstream o2 (sensor 2) and it was very oily. I checked the readings from both o2 sensors and they seemed responsive when applying throttle etc. The readings I got from o2 sensor 1 was about 1V at idle and peak at 3.157 when giving it some throttle. For sensor 2 I saw 0.35V ish at idle and peak at 1V with some throttle. I also checked the MAF which read 2.4g/s at idle and got up to 14.5 with some baby revs. I have spent some time looking for another vacuume leak but no luck. Also ordered spark plugs.
Anyone experienced the same thing or have tips or any idea what to do next?
Old Oct 28, 2023 | 10:34 AM
alone's Avatar
merhaba benim aracımda silkeleme sorunu vardı hava akışı metre (maf sensörü) değişikliği yaptım sonra P0172 arızası oldu daha sonra eskisini taktım birdaha P0172 arızası olmuyor sizde maf sensörünü değişip test edebilirsiniz
Old Oct 30, 2023 | 01:57 PM
JettaRed's Avatar
Veteran: Army
Running rich could be a bad fuel injector since you covered the other stuff. And high CO levels could be an inefficient (bad) cat. Sensor 2 (post cat) being oily is a little confusing. The cat is supposed to run hot enough to burn off any oil.
A dirty/clogged fuel injector won't atomize the fuel enough for proper burn.
All the other codes point to sensor 2 being bad. Did you clear codes after you switched out the o2 sensors? They could be old codes. Did you replace the o2 sensors with OEM/OE/Genuine parts or aftermarket? Since Mercedes seem to be temperamental about anything electronic, I would stick with Genuine or OE parts. Are you in the US?
Or you could also have a bad catalytic converter.
Old Oct 30, 2023 | 04:28 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
deciphering issues into solutions
Originally Posted by Andre1234
Hi!
PLS PROVIDE ENGLISH DESCRIPTION OF YOUR CODES.
This will help us understand your issue - Volunteer friendly members can help narrow things down to a solution.
