Radiator hose just popped off
Old Oct 5, 2023 | 07:21 AM
gwcrim's Avatar
SL63 - R230
5000 miles ago I had a coolant flush done in my '09 SL63. I don't know if the place pulled off the lower hose. Nothing seemed amiss for almost two years. Monday I was driving down a city street and pulled into a parking lot just as my 'check coolant level' light came on. A large puddle dripped on to the ground. Got a tow home and figured I had a bad radiator but upon inspection, the lower hose had come off. I looked it over closely and it all seemed OK. The O ring was intact, soft, and compliant. The spring clip was intact, in correct position, and had tension. I couldn't inspect the entire male end on the radiator but it felt fine. So I cleaned everything and put it back together. Took it for a 20 mile drive with no issues. I fully expect another failure, unfortunately.
WTF happened? How did the hose just pop off?
Old Oct 6, 2023 | 04:32 AM
ygmn's Avatar
2015 E400 Sedan
jumped off due to pressure inside exceeded hose clamping forces.
So how is your pressure cap which acts as the relief valve?? is it really old and maybe stuck?
Old Oct 6, 2023 | 07:46 AM
gwcrim's Avatar
SL63 - R230
As far as I know, it's the original cap. Probably 15 years old. Wouldn't hurt to replace it.
