Spark Plugs and Brakes on c230
Old Nov 10, 2004 | 03:21 PM
tfalater's Avatar
I opened the hood to change the spark plugs on a 1997 C230 and .....WHERE ARE THEY?
How do you change them? Is there any online manual or other service manual I can buy for it? I found a guy selling CD's a repair manuals on ebay and was going to buy one from him but I'm not sure. Sometimes, they just say, "Take your vehicle to a qualified Mercedes mechanic.."
Also, I want to do the brakes too....any material on that that is accessible to me?
Thank you..
Tom
Old Nov 10, 2004 | 06:13 PM
saturnstyl's Avatar
Ya know that metal plate in the center of the valve cover with the 3 allen head bolts holding it on? They are under that.
Old Nov 10, 2004 | 06:19 PM
tfalater's Avatar
Hi,
Thank you. I thought so but I wanted to ask first.
Is there a gasket or that I would need after I take it off? Or should just buy the plugs? Any recommendation on the plugs? Buy them from the dealer right? Or is there one brand that's better on a c230 with 100K miles?
Tom
Old Nov 10, 2004 | 08:50 PM
electric blue's Avatar
Gasket
Their is no gasket under the cover. Once you remove and are ready to reinstall the cover just screw it back down. I think Bosch plugs are what you should use. Your brakes are pretty basic to change. I mean doing it at home might be a bit difficult if you dont have the proper tools and jacks. When i perform a brake job on a mercedes, i never turn the rotors, i always have them replaced. Sometimes you can get away with not replacing your rotors if their not to dished out, but if you can afford to then i think your best off.
Old Nov 10, 2004 | 09:09 PM
saturnstyl's Avatar
I agree with everything he said....
Old Nov 11, 2004 | 10:17 AM
tfalater's Avatar
Thanks for the advice. I agree that I should change the rotors and not turn them and I plan to do that. And I will replace the brake pad sensors too.
And I'm told to stay away from those 'lifetime' pads and metal pads and stick with high quality regular ones.
When I do the plugs, I'll change the air filter, fuel filter, oxygen sensor too.
Tom
