08 CS 550 Loose rack and pinion
08 Cls 550
Hello, Im hearing a noise when I turn my steering wheel back and forth an inch one way an inch one way maybe and it has a thumb or clicking noise I got my son to do it and I can trace the sound down to the rack and pinion what's the recommended repair there, thx
Received 3,434 Likes
MY'14 W212 M276 3.5NA @60kMi
loose front end
The steering rack is connected to the wheel hub with ball joints that are called TIE RODS.
- Two inner tie rods
- Two outer tie rods
Replacing these steering parts guarantees you'll need a front wheel alignment....
So while you are at it, replace the front control arms and ball joints as well to have a good steering control.
Struts and bearings: as tested.
Complete Kits are made available because these parts are interactive. Once you remove the free-play from control arm, it stresses rear ball joint...
I almost forgot stabilizer rods, they are the first suspension part to register wear.
I was going to say stabilizer link usually goes first…but if when turning at a stand-still…upper strut mounts/bearings/hats?
I also know that some in the w203 community have reported “loose/shot” rack mounts/bushings and thus clicking and unwanted noises/play…
