Easy Question '95 E320 radio
Old Dec 2, 2001 | 01:17 AM
Haasman's Avatar
'91 300E + '95 E320TE
Does anyone know how to remove a '95 E320 radio? I need to change the bulb. I have the code.
Thanks in advance.
Old Dec 2, 2001 | 03:32 AM
linh's Avatar
99' SLK 230 & 01' CLK 430
I don't really know what your radio look like but if it the same radio as in the slk or Clk then look at the bottom left and right corner of the radio, you should see two flat hole. That hole it for you to slip in the Mercedes radio remover tool. I used my wife hair clip about 1/4 in. wide and about 3 in. long then slip it in all the way until you able to remove the radio. Good Luck.
Old Dec 5, 2001 | 08:53 PM
uwannadeal2's Avatar
e320
Radio Removal
Look for two tiny slots--Basically your are held in with spring loaded wedges. When you depress the tiny springs on the right and left you can wiggle the radio out.
You can use cheap jewelers screwdrivers, the pinty end of a keyhole saw or I have the tool if you need to borrow it.
I can spring for a 34 cent stamp.
I just bought another E320 radio on Ebay.. and the seller didn't give me the code..
What are the basic instructions for resetting the radio...
Also is your CD player on the rt or left side of the trunk.
Thx
uwannadeal2@usa.net
