So today I attempted to roll down my rear passenger window down, and it worked but after I I attempted to roll it back up I heard a crunchy sound and next thing you know the window didn’t go all the way up and now it doesn’t go down. I forcefully used my hands to pull it up.
Anyway so I took the door panel out and saw broken white circular plastic (see attached photo I’m suspecting that’s from the window regulator ?) the motor works because I hear the sound when I press the button but only from the drivers side when I pressed the button at the back it doesn’t work at all the wires seem ok. I will check the fuse it could be the fuse but what if it’s not the fuse could there be a short circuit somewhere deep ??
long story short is there a way to just replace this white plastic circle thingy (what is the correct term for that)? Instead of replacing the whole window regulator ?
If some help/advise could be provided that would be great.
I think you're going to be stuck with new regulator because 90% chance the center shaft is not removable. Look at rockauto dot com for multiple choices in stock.
