Installing cd changer
Old Nov 25, 2004 | 08:42 AM
ardsar's Avatar
Hi
Can anyone tell me how easy it is to add a cd changer to the c-class coupe (2004 UK model) I have the DVD comand (Becker) unit fitted at the factory. Are the leads already there and just need pluging into the Changer. Also i understand that these cars use a CAN bus and therefore does any software updates need to be done.
Andrew
Old Nov 25, 2004 | 08:37 PM
scorchie's Avatar
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
Originally Posted by ardsar
Hi
The US cars do not even come with all the leads, so it is unlikely that your car has all the leads. It is even more likely that it is missing the power lead which comes on a US car, but you need to go digging around to check for sure.
Even if the leads were all there, the other end of the fibre needs to be configured into the loop and so there's more work to be done.
CAN bus has nothing to do with the CD changer, nor whether any software updates need to be done or not.
You may be better off letting someone else do the install for you.
-s-
