W245 key problem
Your key is fine, the chassis is soaked...
-- 1st word of advice: save your battery from draining flat with a float charger (ctek/noko)
-- 2nd its not just gonna stop acting up. Don't replace "lucky parts"... Instead use a good MB scanner to diagnose what is acting up right now.
-- You said fuse box is dry: good deal you save $2,000 bonus nicely!
-- Let's see what the fault scan says about networking faults??
Perhaps footwell area got swamped... it's a Mercedes, who knows ??
Notice how chassis is awaken by the door opening... CAN-D will definitely respond to scanner. If not that's where you're going to go focus to resume power.
EIS:Ignition commands F-SAM to power up additional modules towards key validation + engine run.
Then I put the first dot, the second dot and the start signal and it recognizes it well...
Is it the key or the EZS, I'm sure it is... the key being placed activates and deactivates if you move it a little
Some fault codes were retrieved from the chassis.
Translate codes into meaningful actionable language.
Unsure if it is keyfob issue...
If active then your ESL needs replacement with an emulator module.
See Internet for "ESL Emulator service".
