W203 ecm programming
Old Jun 17, 2025 | 12:11 PM
Nostradamus001's Avatar
W203 C180 M111.951
Good day all.
Apologies if this has been asked before. I have comw across a thread or two, but its either a dead end or not quite what I am looking to get info on.
I ran into a problem where the emissions control on my w203 has been "switched off". Its a long story..... Anyway, i would like to have it switched back on, because I am getting zero STFT's and zero readings from the O2 sensor, and zero check engine light, even if started with the O2 sensor disconnected.
My question is....what is needed, besides the C3 or C4 hardware? I have downloaded a 75gig ghost image of the Xentry software, just waiting on the laptop to come back. Is everything that I will need in the Xentry package? This is what is in the 75gig file I downloaded
MB XENTRY 5.2012 (FIXED HTT)
wis/das VAS v19,(skoda,seat,vw,audi,bentley);
renaut clip 117; lexia (final updates);
Peugeot planet 2000(final updates);
autocom 2012.3 INCLUDE KEY GENERATOR
autocom DELPHY 2012.3 INCLUDE KEY GENERATOR
opcom;
BMW SCANER 1.4 (NEED HARDWARE)
ZEDBULL (NEED HARDWARE)
SKT100 (NEED HARDWARE)
MPPS GALLETO
WINOLS 1.7 ECM TITANIUM 1.61
VOLTA ECUSAFE 2.0 INCLUDE KEY GENERATOR
EGR REMOVER 1.4
autodata 3.38;
tolerance data;
vivid workshop
Gosh I can see some of yall pulling that faces and slapping your foreheads saying....idiot! Just pls bare with me.
Any guidance will be appreciated.
Old Jun 17, 2025 | 02:13 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
What is your real priority:
Run your engine well again or
build yourself a scanner ?
Was your ECU firmware altered to hide active faults ?? Replace it!
It's not only ECU tweaks... real things happen to engine components when ECU is tempered with.
We are talking lean/rich mixtures have consequences -
Don't expect to swap ECU and find this engine ready to run well.
Keep that in mind before you start throwing expensive parts at this: ECU, injectors, pumps, cats, lambda, valves, ignition coils, ... for what result???
Old Jun 19, 2025 | 01:41 PM
Chevota's Avatar
E550 Coupe 2wd (2016)
I would use KESS to copy what is on your ECU now, because you may need it. KESS is like $60 on aliexpress. I can help with how if you need. Then you can either find a copy of normal programming somewhere to load in, or have someone undo what was done. It's a lot easier to delete that stuff than to undo it; fyi, but I know where to ask if you need. My guess is the car was modified, or hosed, and they just wanted the check eng light off so they could smog it and/or sell it. So if you undo that you'll likely have a CEL forever.
"If" you get Xentry working yoy can have Benzninja load tge ecu. Either join his lifetime service or I'm sure he'll do a one time job for $xxx. Better to join because you'll likely need him again.
