Transmission problems.
Old Aug 1, 2025 | 05:34 AM
Freddie70's Avatar
C220 cdi sport AMG 5g automatic
My 2009(may) C220 cdi sport amg has lost the ability to use the tiptronic(automatic 5 speed) gearstick and also the the paddles don't work. It will not shift gears above 3rd gear. Have replaced 4th & 5th gear solenoids and fluid and tried another TCM but no change! what action is recommended next please, regards freddie70.
Old Aug 1, 2025 | 11:45 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
TCM NETWORKING ISSUES ??
Originally Posted by Freddie70
My 2009(may) C220 cdi sport amg has lost the ability to use the tiptronic(automatic 5 speed) gear stick and also the the paddles don't work.
regards freddie70.
You've done the right things but gearbox is still not shifting all gears well.
> Can the gearbox shift all its gears well but tip-tronic & paddles stay ineffective ?
or is your geabox shifting only up to 3rd but nothing above?
> You need to read the TCU live data with a scanner to see it's status. Then what's not happening will become obvious.
Old Aug 31, 2025 | 08:22 PM
Alexie's Avatar
Check the conductor plate inside the transmission valve body. It's a common failure point on these 5G-Tronic boxes that causes exactly these symptoms loss of manual shifting and getting stuck in 3rd gear (limp mode).The solenoids you replaced are often fine; the faulty plate is the real culprit.
