“From reset” Trip meter reset itself.
Old Aug 6, 2025 | 12:51 AM
fortuner's Avatar
GLC 250d
GLC250d Trip meter “from reset” reset itself. This happened after replacement 12V battery by authorized MB dealer.
Anyone experienced this problem and how to correct. I just have SD connect ,xentry ,vediamo.
Old Aug 6, 2025 | 01:55 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
LOST "FROM RESET"...
You have use of the very best factory tools: what does the IC Module shows you??
You mention your "Trip Meter" got reset when battery was disconnected - If it's important for you to preserve this data, use a battery backup when main power is disconnected.
Old Aug 31, 2025 | 08:20 PM
Alexie's Avatar
This is normal after a battery replacement. The trip computer from reset is volatile memory and clears when power is lost. It's not a fault. You can't correct it; just reset the trip meter manually to start a new count. Your dealer did nothing wrong.
Old Aug 31, 2025 | 09:40 PM
fortuner's Avatar
GLC 250d
Trip meter
It’s not reset one time after battery replacement, but often reset without exactly tIme or mileage
Old Sep 1, 2025 | 01:33 AM
UNSTABLE IC MODULE
The Cluster is an essential network module.
You're doing well to address this issue to regain basic functions.
Check/clean painted GND posts at front footwell
Scan the whole chassis with your Xentry tool for network chaos bugging the IC module.
