Windshield washer fluid heater - water/coolant mix
In San Diego I don't really care about heating this reservoir. And I plan to bypass the spiral. Here are the two questions:
1. Is it safe to bypass? Does the valve in the heating element play any role in the engine cooling system?
2. Why there was no bubbles? :-)
FYI: I have blue washer and blue coolant but no leak.
Perhaps your coolant leak is somewhere else... radiator itself or relief cap off gasing after engine stop.
EDIT: My bad. I now see what you are referring to. Unless your son had different color washer fluid, I would not assume the blue color is due to a leak into the washer tank.
I guess the main question still remains - how could the coolant escape, but pressurized air can't?..
