96 S500 Transmission orings ?
![Question](https://mbworld.org/forums/images/icons/icon5.gif)
Does anyone know how to locate and replace the 2 transmission orings on a 96 S500? I found and removed the plug, but can't figure out how to remove the socket.
Any advise would be greatly appreciated.
Unplug electrical connector. There is a 7mm bolt in the hole it goes in. Unscrew it, but it wont completely come out. Grasp and remove the plastic socket, there is your two o-rings you are supposed to replace.
Thank you for the help. I cleaned around the socket, loosened the 7mm bolt, removed the socket and replaced the two o-rings. Things sure go smooth when you have the proper instructions. Should the o-ring on the plug be replaced?
