2013 E220D - EML - P047128
Old May 7, 2026 | 09:46 AM
J16SDA's Avatar
2013 Mercedes E220d
Hi, I'm new to this forum and have used the search function but all threads related to this seem to die off and solution never found.
I've got a 2013 E220d, I'm having a loss of power along with the code P047128. I'm UK based and live near Wakefield/Pontefract area.
When the car is cold it drives perfectly fine, once warm it has a loss of power - delayed gear changes and struggles to get up to speed.
I've replaced the exhaust back pressure sensor for a genuine sensor from Mercedes - i've plugged my Icarsoft V3.0 in and read the values etc - shows 1.02bar pressure on idle when cold. but jumps upto 2.02 and limp mode from what I can work out. I've got the car booked into a specialist in June (earliest appointment) but I want to try and fix before this.
Any help with me making sense of the live data would be great. Or even someone who can fix it before June.
Thank you
Old May 7, 2026 | 02:37 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
diesel back pressure
Thank you
You've done everything right all the eay to a new sensor.
The next item is to deal with the pipe that plugs up with soot needs cleaning/replacement.
In addition you can buy quick live access to the No1 professional repair network at www identifix dot com for exact PRO fixes specifics to your VIN at DIY cost.
Not affiliated whatsoever... I simply find identifix a great offering for DIY'ers that used to be pro only.
