722.9 Solenoid/Regulating Valve service
I'm preparing to service the regulating solenoids on my 722.904 transmission in the near future. Now, I don't have access to Xentry/MB Star but I do have access to a friendly shop that can prompt a TCU adaptation for me, after I do the service. I presume that is sufficient after this work. Can anyone here please confirm that I won't require Xentry/MB Star for anything else, except this adaptation, if I take the valve body off the transmission to remove the solenoids for service?
I intend to remove the valve body, clean the solenoids including their mesh screens, clean the other mesh filter which is on the valve body/nearby, of which the name I can't recall now, replace the solenoid o-rings, and put it all back together. I am comfortable with the procedure, but and just hesitant about the software/Xentry work I will have to do afterward.
And yes, my process of diagnosis and a reasonable understanding of automatic transmissions has led me to this one thing as the cause of a few problems.
Thanks for your input.
Warm regards,
Rohan.
Warm regards,
Rohan.
What is it you are trying to fix?
What symptoms?
How did it get that way?
Can you use Xentry to diagnose BEFORE cleaning valves screens ??
The specific solenoids implicated, according to the gears I have trouble with, are the B1 Y3/8y5 and K1 Y3/8y2. I'm at the point of diagnosis where I want to just go in and test my theory.
But my question is, will I need access to Xentry for anything (other than prompting a TCU adaptation again) if I continue with this repair?
Thanks.
Thanks.
You want to go in a low milage 722.9 to replace solenoids to gain fresh O-rings because of poor low gears shifts...
Did you get any active TCU faults ?
Bad O-rings really are on the clutch pistons where shift frictions produce heat...
I have a more practical take on poor low gear shifts (2,3,4)... being caused by the engine THROTTLE not caused by poor TCU work.
Do you find your tranny always driving in the wrong gear selection... like 4th at 20mph or 5th at 30mph always having to manually intervene with gear selection ??
Overall response feels delayed and really heavy until rev's are up above 2500 to 3000R. That is common but not normal.
> Snappy vs. slippery...
Once engine setup is delt with, tranny automatically learns to performs snappy matched Rpm shifts all the way down to 2nd gear (... just not overnight!).
It learns appropriate gear selections, shifted near 2000R.
Matched rpm requires precise throttle else tranny is stuck with slow slippery shifts that work out hot frictions.
Pay attention to engine response to know how tranny is shifting your gears....
Smart tranny learns to adapt to the engine all by itself for seamless shifts.
Ppl report quick relief with getting TCU adaptations...
Pulling the valve body to clean the solenoids Is not impossible if you have any mechanical skills, but you should be sure the problem is with the solenoids first. XENTRY does have a process to calibrate the valve body solenoids, so you might want to try that first. From what I understand, solenoids are matched to the valve body at the factory (whatever that means) and do not have replaceable parts. But, whatever you do, make sure to properly tag each one so you know where it goes back. Put each on in a baggie and mark its location.
