Motor oil recomendation on 58k sl600
Just wonder what motol oil (brand and weight,sintetic or not)would you use on 58k mls sl600.
So far I've been using Mobil1 10w-30w,is it time to switch to 20w-50w?
That's about it!
The car drives like a dream!
That's about it!
Type of Oil
Here in Houston Texas we use Castrol 20/50 on most imports. We also use Mobil 1 as are choice for Synthetics.
Been awhile since I did an oil change on a mercedes SL 600. I do know the oil filter is a pain to get to because the Airflow meter needs to be taken out in order to reach it and the car taking between 10 1/2 to 11 gts of oil.
1 Post
2014 RX 350 F Sport, 2007 Scion tC, 2000 ML 430 Money Pit Finally Gone! Oh Happy Day!
That's about it!
That's about it!
1995 SL 320
oil for SL320 500 and 600
Ewing Autohaus in Plano uses Mobil 20W50 when they do an oil change.Texas has mostly average temperatures with 4 hot months in the summer.So this seems to be a good viscosity for our climate.If you change your oil and filter every 5000 miles then this is fine.If I was doing it every 10,000 miles I might opt out for Mobil One synthetic or Castrol Syntec 20W50
58K miles is still a young engine. You bearing clearances should still be tight. I would stay with the MB recommended Mobile One for at least another 58K miles, then think of swithing to a heavier oil. Mobile One shouldn't loose it's viscosity in the hot Texas summer.
