Replacing block heater - 1984 300D Turbo
I keep the block heater plugged in overnight and when the car is home during the day. Unfortunately, it must be parked outside. I suspect that the block heater is not working. I can find replacement kits for $50.00 US, which seems reasonable. Has anyone ever replaced one of these and if so, are they difficult to replace and do you have any pointers?
Thanks in advance.
Here are so other suggestions for getting a diesel to start on a cold day.
Use a synthetic light weight oil during the winter. When I lived in WV, on days like you have in Ohio I could start my diesel w/o plugging it in to keep it warm by using Molil 1 or Castol Syntec.
After your glow plug light goes out, you need to keep cranking the engine until it starts, even if it takes 30-45-60 seconds or more. Stopping and starting over again makes it harder to get it started the second try. Check anbout this in your Owners Manual.
You can add an in-line fuel heater. This dosn't help your starting problem, but once you get your engine started, it will keep the fuel from gelling in the filters.
You can use up to 50% kerosene to cut your fuel to made it flow in cold weather, but this cuts down on fuel economy as kerosene has less energy.
Another suggestion, that causes many arguments in this forum is to add one gallon of gas, to a full tank of diesel, to cut the fuel, and keep it from gelling.
Half fill your tank, add one gallon of gas, then top off yout tank, to mix the gas with the fuel. I have done this without problem in all my dieses, but others on this forum will argue very strongly against doing it.
Auto Parts stores sell a heated dip-stick for about $10, this would be an inexpensive way to heat your engine.
I do have a follow up question about excessive starting times. I have read some other posts that suggest letting a diesel engine crank for up to a minute on very cold days. Do I run any risk of damaging the starter by doing so? This is the first diesel I have ever owned, so I am still getting used to the unique qualities in a diesel engine.
Thanks again.
Thanks again.
Steve
