Brabus Oil Temp.
Brabus K3
Brabus Oil Temp.
Hello;
I want to install a BRABUS/VDO oil temp.
The sensor goes where now is the oil drain plug; the problem is that the sensor screw is 12mm; and the drain plug hole I think is 13mm.
Any idea of how I can screw it there or if there is another hole where I can put it?
Best Regards.
Ruben.
Best Regards.
Ruben.
GL320CDI / C63 Edition 507 Coupe (EDP) / E63 S (on order) / G500 / Smart Brabus
I believe the problem is you are trying to install it in the wrong hole! You shouldn't replace the drain plug with a sensor...
"Wrong hole? What do you mean, wrong hole?"
-s-
-s-
Originally Posted by rubensans
Then, where is suposed to go?
-s-
