BRABUS SV12S 730HP BUILT BY BRABUS NA
35,XXX MILES
PERFECT CONDITION
The pinnacle of powerful engine tuning is the Brabus S V12 S Biturbo engine. Its displacement is increased to 6,233 cc with the help of a custom crankshaft, a larger cylinder bore and forged pistons. The inner workings of the engine are also modified extensively: gas flow in intake and outlet ports of both cylinder heads is optimized, and the engine is fitted with sports camshafts.
The Brabus engine specialists further equip the engine with larger turbochargers, more efficient intercoolers and a stainless-steel igh-performance exhaust system with four tailpipes and metal catalysts with low backpressure. Newly programmed engine electronics ensure not only the optimal synchronization of all new components but also contribute to maximum power yield and to meeting all current emission limits.
The Brabus S V12 S Biturbo engine develops a whopping 730 hp / 537 kW at 5,100 rpm. The peak torque of 1,320 Nm is limited electronically to 1,100 Nm, available from a low 2,100 rpm.
$109K
BORIS
BERMAN495@GMAIL.COM
