1974 Mercedes Benz 280C
Subscribe
Nov 24, 2015 | 08:53 PM
Located in Seattle Area - $7650
Amazing condition, Full Service History Original/Stock Classic Pillarless Coupe.
Originally Purchased and Serviced by Mercedes-Benz of N.A. Jacksonville, Florida, then moved to Huntsville, AL before coming to the
Northwest in 1987.
I would not hesitate driving this car cross-country.
Includes Original owners Manual, Maintenance booklet, Owner's Emissions Systems Manual and
Official Mercedes Spare Parts Catalog (with full parts diagrams and exploded views).
Original Factory Data Card included as is a 1974 Full Line Brochure.
Seems to be all original paint with a few areas of localised touch up.
All original Factory Glass.
Mercededs "Dark Olive" (Code 291) with Original Green MB-Tex interior (Code 166).
Original Factory Tool Roll with Spark plug socket.
Original Factory jack in good condition.
Original Factory Spare tire from 1974 that still holds air! (probably still some "West German" air in there!) It's a Dunlop SP 175 SR 14 Made in Germany with a date code of 274.
The Tire has no cracking but the rubber compound is hard.
Audio is a Clarion PE-751A that according to the receipt cost $444.46 in 1979!!
4 speed Automatic Transmission with Floor Shifter.
Rebuilt at approx 120,000 with receipts.
Starts as it should in second gear and runs through the gears well with no flares or clunks. No delay going into reverse either.
Kick-Down works.
Foot operated Windshield Washer also works.
All dash lights and guages work except for the clock which only works intermittantly (I can hear it working but the dial doesn't always wake up.
Odo, Trip Odo and Speedo work great and are accurate according to GPS.
Heat and defrost Slides move easily and freely.
Blower works in all speeds and defrosts quickly. This is important because as most of you know, the car was built around the blower!
Vacuum door locks work great.
Photo's don't show the door pockets, but they are present and will be included with the car.
Brakes have great bite and stop the car on a dime.
Power Steering system works great with no notchiness or noises.
Factory A/C car but cannot confirm it works as the adjustment bolt for the belt has been rounded off. All A/C components are present and appear to be in good condition.
Original wood in great condition.
Non Sunroof car. Headliner and cross bows in great condition.
Dash Odo shows 61,XXX miles, (5 Digit Odo) but it is 161,000 and as this is my Daily Driver, this will increase.
Original green Floormats and carpeting in good condition.
Original MB-Tex in fantastic condition with no rips and tears.
Doors close with a typical Mercedes "Thunk"...Better than most recent cars never mind one that is almost 42 years old!
Power windows Open and close with full range except Driver's side rear window. Not sure if switch or something else,
but glass is firmly on track and fully closed.
Original Hub-Caps in great condition with one missing some paint.
Original trunk mat included, but could be replaced as it's hardened over the last 40 years.
Trunk light works.
Interior dome light works as it should with the door and the rear light which is controlled by a dash switch works also.
All floors are solid and appear sound with only the Passenger side showing a half inch by 5 inch section of rust.
Small rust area in front of the rear subframe on the passenger side.
I have not touched these small area with POR-15 or any other anti-rust as I wanted it to be very clear to the Buyer.
All four wheel arches are sound with no evidence of even surface rust.
I have been all over this car with a magnet and could not find any issues.
Center exhaust box and rear muffler replaced with original tip . (The exhaust they removed was original but had too many holes to keep)
Wipers are quiet and work in all modes.
The Dual Cam M110 runs great with no smoking or oil burning even at full throttle.
The 4 Barrel carb works great (Solex 4A1) with both the Auto choke and secondarys functioning as they should. Base plate appears sound with no warping or vacuum leaks.
All hard fuel lines in excellent shape.
Driveline Flex disks appear in good shape.
Recent Service with new plugs, wire-set and Bosch Distributor cap and rotor.
"Mercedes Service Manual - Passenger Cars Starting 1968, Series 114-115.
Maintenance - Tuning - Unit Replacement" will also be included.
Additional pics here : https://www.flickr.com/photos/549072...57660132508457
1974 Mercedes Benz 280C-img_1925.jpg   1974 Mercedes Benz 280C-img_1923.jpg   1974 Mercedes Benz 280C-img_1929.jpg   1974 Mercedes Benz 280C-img_1944.jpg   1974 Mercedes Benz 280C-img_1962.jpg
1974 Mercedes Benz 280C-img_1963.jpg   1974 Mercedes Benz 280C-img_1984.jpg   1974 Mercedes Benz 280C-img_1999.jpg
Subscribe
Currently Active Users (1)
