FS: 1989 560SEL / Midnight blue / 71k miles
Old Apr 27, 2016 | 12:50 AM
V12Stealth's Avatar
w201,w124,w126
Hello everyone. Mercedes enthusiast (10yrs on the *other* forum) selling a 1989 Mercedes-Benz 560SEL. It has a Midnight Blue exterior with Palomino interior. I bought it 6 years ago from the original owner. It has 71,500 miles. The car has spent most of its life in West Palm Beach, Florida.
Make me an offer or use the auction;
Mercedes Benz 500 Series Base Sedan 4 Door | eBay
Very well documented service history. File literally inch thick with receipts. About $15,000 spent on maintenance in the last 5,000 miles. This includes the following;
Top end engine rebuild and related work;
- New head gasket, intake manifold gaskets, exhaust manifold gaskets, valve cover gaskets etc...
- New valve stem oil seals and guides
- New plenum gaskets (pretty much anything made of rubber in the engine bay has been replaced)
- New vacuum lines
- New timing chain
- New timing chain tensioner
- New timing chain guide rails
- New camshaft oiler tube clips
- New idle control valve
- New coolant hoses everywhere
- New vacuum lines and check valves
- New spark plugs
- New spark plug wires
- New distributor cap
- New engine mounts
- New engine shock absorber
- New engine oil pan, pan bolts, pan gasket, oil filter
- New fuel pump relay
Misc transmission work;
- Various seals and O-rings replaced to fix leaks (B1 reaction valve cover, dip stick o-ring etc..)
- New transmission shifter linkage bushings
- New transmission oil pan, gasket, filter, fluid changed
Rear suspension rebuilt;
- New SLS Rams (hydropneumatic shocks x2)
- New SLS accumulators/nitrogen spheres x2
- New SLS high pressure lines and fluid flushed
- New sway bar end links
- New coil springs
- New spring pads
- New shock top rubber buffers
- New tires (and rims were professionally refurbished)
Steering work;
- Rebuilt steering gearbox
- New steering tie rods (inner and outer on both sides)
Body work;
- New rear windscreen. Imported from Germany (replaced due to delamination of defroster element)
- New hood insulation
Heater work;
- New HVAC blower motor
- New heater monovalve
Brake work;
- New brake discs/rotors (x4)
- New brake pads (x4)
Interior work;
- New odometer gears
- New cruise control stalk (cruise control works!)
- New floor mats
- All wood trim refinished at Madera Concepts
Misc;
- New Bosch battery
Always genuine Mercedes parts used when available. No URO or Febi-Bilstein Chinese crap installed.
Under body was rust proofed with Corrosion Free 3000 many years ago.
The car starts and idles well. Good oil pressure. No vacuum leaks. No overheating. Transmission shifts well and kick down works. No leaks on garage floor.
Click here for high resolution photos
Car is registered and insured in Santa Clara, California. Clean Californian title in my name. Feel free to send me an email or give me a call (Outside office hours PST please). My cell number (in German of course) : sechs sechs neun - zwei zwei zwei - neuntausen
Attached Thumbnails FS: 1989 560SEL / Midnight blue / 71k miles-interior-front-1dsc02567.jpg   FS: 1989 560SEL / Midnight blue / 71k miles-exterior-lf-dsc02548.jpg   FS: 1989 560SEL / Midnight blue / 71k miles-exterior-08-quarter-fr.jpg
Old Apr 28, 2016 | 01:11 PM
V12Stealth's Avatar
w201,w124,w126
Just wanted to say if any of you guys are creating ebay accounts just to bid on this, please get in touch as soon as possible. Preferably by phone (number in the auction description). I will cancel bids from new/zero feedback users to prevent time wasters ending the auction and incurring me Ebay fees.
