ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
sway bar for ML
Old May 12, 2006 | 01:49 AM
MBfan89's Avatar
sway bar for ML
I herd that some one put an h and r sway bar on there ML and it helped it with the handling around corners and it helped it from body roll what do u guys think abt that is there any defects with that
Old May 12, 2006 | 09:36 AM
55fanatic's Avatar
00 MB ML55, 91 Toyota Supra Turbo(sold), 06 E500(gone), 03 BMW M3
I dont believe the H&R helps the ML55 out as much the sway bar in the 55 is pretty beefy already
Old Aug 10, 2006 | 03:08 PM
Tone's Avatar
It is much more helpful to comment on things you have already done than contribute to the erroneous information on this board. YES, the H&R bars makes a noticeable difference on the 55 - 3mm larger doesn't sound like much but combined with the stiffer steel and design, it is better and worth the expense if you track or drive your 55 like it was meant to be driven.
Old Aug 10, 2006 | 07:11 PM
///AMG55's Avatar
XLR
""erroneous!"" -- Wedding Crashers
