ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
How do you reprogram the key remote of 01' ml55
Old Sep 13, 2006 | 10:55 AM
Kingston39's Avatar
ML55 AMG, Rover HSE, 65 Vette
how do you reprogram the remote key for the ml. I changed the battery b/c it was getting weak and now it wont respond. the battery is in correct and the remote lights up, whats the trick?
Old Sep 14, 2006 | 10:16 AM
LiquidSmile's Avatar
00' ML 55 AMG; 08' Jeep Wrangler Unlimted (4 Door)
All these steps have to be done within 10 seconds
1. put key into ignition and turn to position 2
2. remove key and press+hold the lock button
3. while holding down the lock button press the unlock button 5 times
4. release all buttons
5. press either the lock or unlock button to finalize the programmning
Old Sep 15, 2006 | 12:16 PM
Kingston39's Avatar
Liquidsmile,
Thanks for the info.
I did exactly what you instructed and it locked the doors but it wont work after that. None of the buttons operate. Is there another step after programming?
Old Sep 16, 2006 | 03:54 PM
I am not sure why it did not work.... It worked fine on mine when I replaced the battery.
The first time I did it I was not holding the lock button while pressiung the unlock button five times.
If you are doing the procedure correctly and it does not work right, then you might have to take a trip to the dare I say it.......dealership gasp!
Sucks, but it might need to go there so they can program through the Star Diag. ... If you are good friends with your advisor or bring him some doughnuts or something they might do it for free.. I have heard some dealerships actually charge for it...
Sorry I could not have been more help...
Old Jan 7, 2008 | 03:02 AM
PHML's Avatar
2011 GLK350 P1, Multi-media & AMG Pkg; 2010 E350 w/ prem 2; 2018 4Runner SR5 Prem. 4x4
God....I love this forum....I just experienced the same problem...so I changed the batteries...and nothing worked.
I did exactly as listed in the instructions....and now it works perfectly.
Thanks everyone for sharing your info.
Pete
Old Dec 30, 2019 | 06:26 PM
c32jet's Avatar
Will this process work to program a NEW key fob? My metal section - the piece that goes into the lock - has broken off from the fob.
Old Apr 30, 2020 | 12:14 AM
IgorE350's Avatar
01 ML55AMG 04 ML500 03 ML350 08 ML63AMG
Originally Posted by Kingston39
Liquidsmile,
Hi did you ever figure ot the problem? i have same thing with my 01 ML55 after i program the key it locks the car and after that it doesn't work Let me know please, thanks
