ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
lowering module install
Old Mar 20, 2007 | 02:10 PM
skatsuba's Avatar
07 ml63, 06 CTT, 05 G500, 06 M6, 06 LX470, 05 X5 4.8is
where do you install you renntech module?lowering module install-sashaelm.jpg
Old Mar 21, 2007 | 01:23 AM
tkracing's Avatar
2003 CL55 stage 4 Renntech and 2006 CLS55 AMG
If you arent familiar with where to install the module I would recommend having it done by an experienced installer. If you need help with a shop to install let me know..
Old Mar 21, 2007 | 12:24 PM
skatsuba's Avatar
no.
i dont know where place to put it in car
Old Mar 21, 2007 | 04:39 PM
MSDLTD's Avatar
ML63
It is a piggy back module with 4 seperate height adjusters, one for each wheel...it goes under the drivers seat...
you could adjust each wheel independently
Old Mar 22, 2007 | 02:50 AM
skatsuba's Avatar
i know, i already have this module but i am trying to find place where i can easily reach this module everytime i want. If i want to raise it or to low it i dont want to go under the seat...
Old Apr 17, 2007 | 11:49 AM
skatsuba's Avatar
what numbers do you use in LF RF Rear(0-7)?
Old May 15, 2007 | 01:09 AM
kokanee's Avatar
07 ML63 Silver Dead at 85k, 14 RS5, 05 SL600
Did you get the sheet with it? Normally the front have to be adjusted separately so they are level. Don't make the front and back even height or you will have your lights in everyones eyes. You will also eat tires if you run it low all the time.
I have 3, 5 and 4 (LF, RF, Rear) This is around 1 3/8 lower than stock.
Old May 15, 2007 | 06:54 AM
skatsuba's Avatar
why do you have 3,5 LF and RF? why not 3,3?
Old May 18, 2007 | 10:18 AM
greenbeast's Avatar
SL55 AMD
I have mine set at 1, 1, 1, 1, and the car jump a lot!!!!!
Old May 20, 2007 | 01:17 PM
kokanee's Avatar
The renntech dealer set it level to start. Apparently they often require different settings to be level. 3 and 5 had the front L and R the same height above the tires when on a flat slab. With the above settings and the back at 4, the back is about 1/2 inch higher than the front. This is similar difference to the stock difference. When the back was level with the front I was lighting up signs 500 yards down the road.
Old May 20, 2007 | 04:12 PM
SUNILP's Avatar
2015 E250D
The back is not adjustable individually. Only one adjustment for the entire back as there is only one sensor on airmatic cars anyway. Rennech presets the dials at 3. You can lower a total of 2 inches. Settings are 1-7. Mode setting is 1 = airmatic, 2 = ABC
Old May 21, 2007 | 03:40 AM
kokanee's Avatar
Sunil can you tell me what airmatic versus ABC means as I was never told.
Old May 21, 2007 | 07:06 AM
SUNILP's Avatar
2015 E250D
ABC = Active Body Control. A hydropneumatic type of suspension found on S, CL, SL class cars.
Airmatic is air suspension found on GL, E, CLS, etc...
Old May 21, 2007 | 02:01 PM
kokanee's Avatar
So the ML63 would perhaps act the same in position 1 and 2? I am assuming that the 3rd position on the ML (not comfort nor sport) is different than ABC?
Thanks.
