ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Transmision shifting, not doing correct!!
Old Apr 11, 2007 | 03:59 PM
greenbeast's Avatar
SL55 AMD
I notice when I ALWAYS full throttle in first gear, NOT always changing redline that is 7k rpm, it sometimes shifts in 5,500 rpm and sometimes it shifts in 6,000 rpm. I simply can't control that, neither in confort or spor mode in the trans. I can maybe do this but just in manual mode.
Does it normal??
Some tips to correct that?
Thanks!!
Old Apr 13, 2007 | 10:28 AM
kokanee's Avatar
07 ML63 Silver Dead at 85k, 14 RS5, 05 SL600
Every once in a while my tranny holds on to bitter end. The up-shift then is quite strong. At most other times the shift is at lower RPM even under full throttle. I'm guessing there is a tranny algorithim that could use a tuners help.
Maybe you have to teach it how you want it to shift?
