Satellite Radio Location?
I got all the parts from Sunil but no instructions and I was going to the dealer but after they quoted me close to 11hrs, I said screw that.
I just pray that it was pre-wired from the head unit back.
Any input will help and save time.
Thanks.
AVB-AMG
"After some digging in the forum, it seems like we'll need a different wiring harness for the SAT receiver, the actual SAT module, and it seems like the headliner needs to drop to install the harness. I know the antenna will be located under the plastic section at the rear of the roof. While I was trying to stick the magnetic antenna from my portable unit I found out the roof is in 2 pieces with the last foot or so is plastic.
Looks like I might have to order the parts from a Seattle dealer and either have them or local dealer to install.
The MB i-pod solution works pretty good, I had it on my CLS and I am thinking of putting one on the ML63 also."
Thought U had ordered all the parts and had them installed already?
I suspect the sat module sits under the rear bench, likely on the pessenger side. It's were the factory entertainment system sits and I would not be surprise to see MB group them together in one spot.
Why not subscribe for a day and download what you need. It won't put a dent in your "11 hours" savings.
http://www.startekinfo.com
I also found out that the dealerships will now sell the parts here in Canada for ONLY $2100 plus 5 hrs labour for the install, if pre-wired. If it is not pre-wired, you have one hell of a job ahead of you. Complete instructions below. I am thinking I might as well buy a new one with the damn radio.
https://mbworld.org/forums/showthrea...=224772&page=2
