ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Evosport tuned evo3 ML63 AMG (580HP)
Old 01-02-2010, 11:53 AM
princemarko's Avatar
CL63, 2014 ML63, 2008 ML63, R500, GLK
Simon,
Questions:
I'm debating on a E63 or a ML63... here is my questions: Do you supply or know of any lightweight rotors and wheels for the 2008 ML63? Also, do you have a setup for the air intake with carbon fiber like Carbonio does?
Old 01-02-2010, 11:07 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
brembo rotors and HRE monobloc wheels
Old 01-04-2010, 06:19 PM
PREMIER SPONSOR
Simon @ evosport's Avatar
Originally Posted by princemarko
Simon,
Questions:
I'm debating on a E63 or a ML63... here is my questions: Do you supply or know of any lightweight rotors and wheels for the 2008 ML63? Also, do you have a setup for the air intake with carbon fiber?
We don't offer lightweight rotors for the ML. As you know, the ML has different brake setup than the E/CLS/CLK/C/SL63. Going to a big brake kit like a Rotora or Brembo would reduce overall unsprng weight and offer better braking. We do offer a couple different options for wheels. Email me at simon@evosport.com for more info.
Yes, we do have a carbon intake setup for the ML63.
Old 01-28-2010, 05:19 AM
Simon
Can ou elaborate on the carbon intake you mentioned? i dont know much about this intake what does it cost, look like, and benefits??
Old 01-28-2010, 02:22 PM
PREMIER SPONSOR
Originally Posted by Maverick1975
Simon
PM sent.
Old 02-13-2010, 10:00 AM
AWDman's Avatar
E36M3 race car/Ferrari F355 GTS/1973 Mini 1275GT/Fiat Abarth/ML63/SLK55
as i have evosport on this thread let me ask a perfromance related question.
can the 3.9 diff from a ml350 be swopped in easily on the ml63? there are 2 -front and rear correct?
Old 02-13-2010, 10:14 PM
  #32
RLx02's Avatar
C55
That sir, is a BEAST!
Old 02-15-2010, 11:04 PM
  #33
benz_addict's Avatar
V12TT
Just saw this, wow sounds great! Great work!
Old 02-16-2010, 02:03 AM
  #34
Hi Simon,
Have you guys dynoe'ed that ML63 yet??
Old 02-16-2010, 09:22 AM
  #35
cls55's Avatar
simon
would the cls55 non 030 front calipers and discs fit the ml63 09?
thanks
Old 02-16-2010, 12:55 PM
  #36
PREMIER SPONSOR
Mercedes-Benz gear changes requires not only a mechanical change, but a change in electronics as well. The EGS conntroller for the transmission must be updated with new gearing information. It gets very expensive.
Hi Simon,
Car is coming back in a few weeks for more work. Will try to get a dyno then. Our dyno here is only 2WD right now, so it will need to be sent out.
Originally Posted by cls55
simon
thanks
They should work but I don't believe it will be a simple bolt-on application. You will probably need to relocate the caliper to work on the ML.
Old 02-17-2010, 07:33 AM
  #37
cls55's Avatar
thanks simon
are you planning on making equal length headers(S/S) for ml63 like the one
the sls or tubular like the 55 kom.in (S/S)
thanks
Old 02-17-2010, 03:55 PM
  #38
PREMIER SPONSOR
thanks simon
thanks
I'm not sure what you mean by "tubular". Do you mean a log manifold? Absolutely not. We feel it's a waste of money and there is little to no power gain in making another log manifold.
With regards to an equal length header, the long tube will make more power. We feel the long tube we offer now will be the best performing header for this application. Even more so than an "equal length header".
Old 02-17-2010, 05:48 PM
  #39
cls55's Avatar
i meant shorty like the one for 55 kompressor.
thanks
Old 02-17-2010, 06:00 PM
  #40
PREMIER SPONSOR
thanks
There's no room for a true shorty header (with collector) in this motor, which is why nobody offers one. Besides, where as the 55K motor can benefit from shorty, this engine really needs more than that to make good gains. Again look at the SLS header, it's a longer header, not a shorty, otherwise MBZ would have done a shorty.
Old 02-17-2010, 06:43 PM
  #41
cls55's Avatar
The one you have on your webpage is it for ml63 also?
i saw the sls headers it is 500 mm and 450mm in length almost equal length.
it`s way smaller than what you are offering.is it doable?
thanks
Old 02-17-2010, 06:51 PM
  #42
PREMIER SPONSOR
thanks
Not sure which header image on our webpage you are referring to. They will look similar but each chassis may have different size restrictions so the headers are unique to the car (different angle primaries, etc.). Here is what our ML63 header looks like:
The SLS header is not a long tube header. Our header is and it will make more power. When you say "is it doable", are you asking if the SLS header will bolt-on to the ML? It will not.
Old 05-27-2010, 06:07 PM
  #43
Have you guys been able to dyno the ML63 yet?
Old 07-05-2010, 05:49 PM
  #44
Hello any dyno numbers yet? How come why not?
Old 07-06-2010, 02:31 AM
  #45
cls55's Avatar
maverick
I salute you,you have stamina.i don`t think you`ll see one.
Old 07-06-2010, 03:49 AM
  #46
maverick
Yes i am not sure how Evospport can state 580hp without any data ??
Old 07-06-2010, 04:13 AM
  #47
cls55's Avatar
580 hp is cranck not rw hp,mkb came out with 551 first then they added the headers and a retune and came out with 581 hp.no pulley,camshafts.imo it`s the same every where, you`ll see the same figure.as i pointed out before,supersprint did a dyno before and after for their headers.tune by it self will net you 15 to 25hp.
Old 07-06-2010, 11:37 AM
  #48
PREMIER SPONSOR
We can post this because we know exactly what power gains our mods make. The power is rated at the crank. Depending on the vehicle, each will have a different drivetrain loss. Our dyno is 2WD so the ML cannot dyno on it. We have been waiting for the customer to dyno the car on AWD dyno. But regardless, we make 580 on the 63 motor with these mods.
Quick Reply: Evosport tuned evo3 ML63 AMG (580HP)
