ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Strange chirping noise from engine while coasting.
Old Sep 14, 2011 | 11:27 PM
Bernie (OOParts's Avatar
A really odd sound has been coming from the engine. Sounds like crickets. It only occurs when I let go of the gas pedal on my 2008 ML63 and only occur when slowing down from 40 to10mph. Below 10mph the sound stops and the sound never occurs until the car is less than 40mph. It'll happen whether the car is just coasting or actually braking. Neutral or drive transmission no change. Interestingly, it usually happens after 5-10 min warmup. When cold, there is no noise.
Here is a youtube video of the sound I made...
http://www.youtube.com/watch?v=NKKeRUNp5fs
Took it to the dealer and they replaced the engine idler pulley and drive belt... but no effect.
Any ideas?
Old Oct 5, 2011 | 08:26 AM
schmick325's Avatar
RR Evoque Dynamic, Benz Valente (work hack)
Strange noise.
Maybe put it on a dyno and see if it does it. May also give you a chance to isolate the noise.
Old Oct 5, 2011 | 08:46 PM
Maverick1975's Avatar
Vath ML63 Brabus C63 SL63 CLK63BS C63BS
Jeez i wish i could help you but have never heard of anything like that. Scares me that the mechanics at MB have no clue
Old Oct 20, 2011 | 08:56 AM
ONEFASTE55's Avatar
2015 MERCEDES ML63-AMG
Check your serpentine belt and also the fan. Sometimes a bent fan blade can cause that. Good luck!
Old Oct 23, 2019 | 01:27 AM
Any ideas?
Did you ever identify this? I have exact same noise under exact same conditions in my ML63
Old Dec 9, 2019 | 06:01 AM
turns out it was the bearings in several of the pulleys, failing after 58,000kms. Replaced 4 I think it was me noise appears from be gone
Old Jan 5, 2020 | 07:13 PM
Noise was gone for about a day but after a longer drive returned so clearly not the pulleys!
Old Sep 21, 2020 | 10:07 AM
icat0963's Avatar
W211 E63
Did you ever figure this out? Mine just started doing it after I replaced the fuel injectors. I have a feeling it has something to do with the intake/intake manifold since that is where it seems to come from. I have an 09 E63 with the same engine.
Old Oct 27, 2020 | 03:51 PM
icat0963's Avatar
W211 E63
For anyone else that stumbles upon this, the cause in my case was the PCV valve, also referred to as the breather valve. Relatively low cost and pretty straight forward to replace.
