ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
ML63 front disk replacement
Old Sep 11, 2016 | 07:41 AM
Ferg AMG's Avatar
ML63 AMG
Does anyone have any experience removing the front brake rotors on an ml63
Old Sep 11, 2016 | 12:28 PM
zenman63's Avatar
ML63 AMG 13 SLK 55 SLK350 AMG kit 07
Yes easy enough whats up?
Old Sep 14, 2016 | 05:38 AM
Ferg AMG's Avatar
ML63 AMG
I need to change the front disks. Looking at them, I'm guessing that I need to remove the calipers and then there is a screw that looks like it needs to be removed. After that it would appear that the disk should come off the hub with a little encouragement. Have I got that right?
Cheers
Ferg
Old Sep 14, 2016 | 12:40 PM
zenman63's Avatar
Thats right, you need to clean the hub face when that disc comes off, wire brush, it needs to be spotless or your new discs will run out in no time.
That bolt can be a pain, impact driver needed.
Old Sep 14, 2016 | 03:11 PM
Ferg AMG's Avatar
ML63 AMG
Fantastic, thank you!
