ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Whould you buy a 2007 ML63 today?
Old Sep 4, 2018 | 02:25 PM
LastLong's Avatar
2017 GLC43
Which one to buy?
Hi, which one will be the best to buy? Good price for work truck.
2007 ML63 AMG
134 000 miles
-four full air suspension replaced
-the front differential replaced
-the front left cardan replaced
OR
2008 ML63 AMG
106 000 miles
-brakes (disk and pad) replaced
-radiator replaced
-power streering pump replaced
I am confused because for $2000 difference, the 2007 has more miles with (air suspension differential, cardan replaced), and the 2008 has less miles on the cars with (brakes, radiator, powerpump replaced)...
Should I put $2000 for less miles on the car? And win one more year (2008).... but never replaced the four full suspension... for now no issue, but soon maybe?
And the 2007 the full suspension was replaced and will no more have issue for long time...
Thank you for help !
Old Sep 4, 2018 | 02:58 PM
Viktori's Avatar
C63 AMG W204
camshafts problem fixed?
Old Sep 5, 2018 | 08:51 AM
LastLong's Avatar
2017 GLC43
Heum, I am not sure, I will ask him, is it expensive to replace the camshafts? It's a commun issue on the ML63 ?
Old Sep 5, 2018 | 10:08 AM
Viktori's Avatar
C63 AMG W204
it's problem №1 in this car, and current owner knows about it, if not he want sell problem car
read here http://australiancar.reviews/reviews...Class&gen=1469
Old Sep 5, 2018 | 11:55 AM
eldos1's Avatar
06' W220 4MATIC (sold) 08'ml63 AMG
I just got a 08' a week ago. The former owner went ahead and did the head bolt upgrade a couple of years ago. I figured the service center looked over the other things when they had it. If they had the heads off for any reason, most likely there are the new style bolts.
Old Sep 5, 2018 | 02:48 PM
Viktori's Avatar
C63 AMG W204
Bolts problem starts from 07.12 manufacture date, if your 2007 car is older then in most you have no problem with this
Old Sep 5, 2018 | 07:21 PM
LastLong's Avatar
2017 GLC43
So I believe that commun issue on ML63 are the camshafts and the airmatic suspension....
What else should I check? Basictly, the engine is reliable I guess...
My last BMW X5 with the V8, has valve seal isssu and it was horrible.... its a commun issue on BMW X5/X6 with the V8.... Hope it not the same thing on a ML63...
Old Sep 6, 2018 | 05:19 PM
Viktori's Avatar
C63 AMG W204
Take car for testdrive, it's automatic transmission have problems 4matic 722.9, like plate samsung in basic and replaced with continental if I remember clear and torque converter, but it's car related, all other stuff you will get with diagnostic star tool
Old Sep 7, 2018 | 10:20 AM
LastLong's Avatar
2017 GLC43
Ok just found an other one... which one will be the best to buy?
2007 ML63 AMG
134 000 miles
OR
2008 ML63 AMG
106 000 miles
-radiator replaced
Old Sep 7, 2018 | 04:44 PM
Viktori's Avatar
C63 AMG W204
both are crap, these cars not good at 50k miles, I even can't imagine what will be with 100k, but it's related to owner, just check list above and if something was replaced it should be original mercedes parts like differential, suspension (bilstein as analog is good) etc
Old Sep 8, 2018 | 11:01 PM
LastLong's Avatar
2017 GLC43
Which one to buy?
All these replacement of part are OEM
