ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
ML55 Injectors
Old Jan 15, 2020 | 10:40 PM
Tomas03's Avatar
W211
ML55 Injectors
I want to replace the injectors in my 03 ML55. There seems to be a lot available for the other M113 engined 55's but not for the W163. Checking it out shows the ML55 has a different part no. for the injector than say the E55 or c55, but they appear to have the same specs. Can anyone offer some alternates or should I just stick with those advertised as being for the ML55?
Old Jan 16, 2020 | 01:45 PM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
EPC shows part number : A1130780149 for The ML55. However, it also shows an updated part number for other N/A M113 AMGs. Part number: A1130780023. I could not find the injectors for the ML55. Some sites show it as discontinued. If I were in your place I'd give the revised part a try, as the E55, ML55, and other AMGs with the same engine have the same fuel rail.
Good luck.
Old Jan 17, 2020 | 08:13 AM
cm60k's Avatar
You have two options:-
A)
OEM #: "113 078 01 49"
Bosch #: "0 280 155 839"
B)
OEM #: "113 078 03 49"
Bosch #: "0 280 156 074"
-;-ZAYED-;-
