ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Modified AEM dryflow air filter fits ML55/W163
Old Jan 17, 2020 | 12:09 AM
kaixdiego's Avatar
190E, C36, C55, CLK55, ML55
Hello All,
After recently acquiring my 2000 ML55 I realized when parts shopping that AEM didn't offer a dryflow filter for this platform. Having used them on my C55 for over a year with great results, I was disappointed they weren't available for the ML so I began looking by filter size and stumbled upon one that I thought might fit.
The AEM filter that I found and ended up getting to work after modifying is part number 28-20408 and is originally for a few different GM vehicles I believe. From looking at photos and comparing dimensions I thought it was worth a shot to see if I could get it to fit. After some precise exacto knifing work with less is more in mind as to not cut too much off, I was able to get it just right.
Filter used:
Amazon Amazon
The dimension for the stock filters are 224x292mm
The dimensions for the AEM filter are 249x314mm
You can check out the video link below to see the process. I will update in upcoming videos of further results, mpg's etc. Initial results are promising and I sense mpg's will increase slightly, time will tell. The overall reason for liking these filters is the cost efficiency of a lifetime filter, no oiling required and the slight performance bump an added bonus. In this video I also cover breather hoses and intake baffle delete, you can skip ahead to around the 7min mark to get to the AEM filter.
Video link:
https://www.youtube.com/watch?v=LZj-...ature=youtu.be
Thx!
Old Jan 17, 2020 | 07:55 AM
cm60k's Avatar
Good job bro., Thanks for sharing..
-;-ZAYED-;-
Old Jan 17, 2020 | 09:19 AM
kaixdiego's Avatar
Thanks ZAYED!
