ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
Starter relay location
Old Jan 25, 2022 | 12:31 AM
alexinvancouver's Avatar
2011 GL350bluetec
Hello every one
2011 GL350 diesel
Does any one know where is the starter relay located?
was trying to google it yesterday and can't seem to find it
Thanks in advance!
Old Jan 26, 2022 | 09:04 PM
2011 GL350bluetec
Originally Posted by Plutoe
Oakey, i don't need to buy a starter relay,
My vehicle won't start and i need to locate the starter relay IN the vehicle to test it to see if it's faulty or my starter not working.
And then go from there to see if it's something else but i just wanted to start with the relay.
Ignition was malfunctioning a few months ago and i took the ignition box apart and soldered 3 pins and she was running fine till the day before yesterday
Old Jan 27, 2022 | 10:19 AM
wallyp's Avatar
2003 S500 2007 GL450
Lots of possible reasons for the starter not working - neutral safety switch, power supply, starter relay, starter solenoid, starter, faulty cable, faulty connection, etc., etc.
It's easy enough to hook up a test light at the starter and see if there is power coming from the starter relay.
Old Jan 27, 2022 | 03:37 PM
2011 GL350bluetec
Thanks, i'm fully aware there are could be couple hundreds of reasons why it won't crank and first i'd like to see if power goes TO said relay
So any chance You know where it is?
a few months ago i had it randomly not starting and i took apart the ignition lock and soldered those pins.
after that she was running fine till last week.
PS sorry just realized i posted it in the wrong section though i don't think relay location is different
moving to X164
