2008 ML 63 AMG Leaking gas under rear floor.pan on driver's side
I drove car all day pulled in driveway shut car off came out 30 minutes later and could smell gas started car and backed up and could see gas all over drive way shut car off and it was leaking like crazy started car back up and moved it off to the side of drive way need help not sure where to start
Most likely cause is a failed rubber hose on the fuel filter. The only answer is that someone will have to get under there and look to see what is wrong.
It was a lose hose at the fuel pump whoever put new pumps in broke the fitting on the hose and did a crap job When a bad mechanic works on ur car and breaks fitting in on the hose and does this instead of buying a 45 hose
