ML55 AMG, ML63 AMG (W163, W164) 1999 - 2011 Two Generations
PCV Valve Screw Type
Old Jul 20, 2022 | 11:38 AM
Dozza07's Avatar
2007 Mercedes ML63
Hi All,
Just finished replacing my PCV valve but with oily fingers i accidently dropped the screw that holds the PCV valve in. Cant seem to find where it went . I will have another look tommorow but if no success does anyone know what type of screw bolt that is? it looked like a M6 x 16MM screw.
Any suggestions?
Old Jul 22, 2022 | 11:39 PM
octoroll's Avatar
2008 E350 4MATIC, 1985 300TD, 2009 ML63 AMG
M6x22 Part #0009907011
Old Jul 31, 2022 | 11:17 AM
Dozza07's Avatar
2007 Mercedes ML63
Thanks for that. I managed to find a M6 x 20mm bolt at the local hardware store that did the trick .
Old Sep 14, 2022 | 07:31 PM
Reiven's Avatar
W164 ML63
Hi Dozza,
Did you have to remove the intake manifold to fit in the new pcv?
Any tips on wriggling the pcv in.
Having troubles with mine as the metal bar under the intake opening is causing me grieve.
Thanks!
Old Oct 22, 2022 | 06:56 AM
Dozza07's Avatar
2007 Mercedes ML63
Apologies for the very late reply. Wriggling the pcv in was a pain in the you know where. I had have my belly on the engine/supercharger and do it by feel. I also had to loosen the hose clamp so i can rotate the hose as it was getting in the way then once the pcv was in, tighten the hose clamp/.
