ML63 AMG (W166) 2011 -2015 (Replaced by GLE63)
Tire Rotation Question
Old May 17, 2018 | 02:43 PM
scottiekay's Avatar
2019 GLC63 and 2018 Jeep Trackhawk
We can rotate the wheels fronts to rear and vise versa correct? I guess I just want to make sure that all 4 wheels are the same and are rotatable. ( this is a really dumb question I know but I am asking because all I know is the spare tire will not fit the front tires, I learned this the hard way).
Old May 26, 2018 | 08:49 PM
E55 KEV's Avatar
Veteran: Air Force
2024 GLE63s / 2016 GLE63s (traded) / 2016 E63s / 2002 E55
Hoping I never get a front flat also.
Old May 27, 2018 | 07:09 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Just about any rotation pattern works now. But I use the pattern for all wheel drive cars, not cars that are primary front wheel drive but the rear kicks in for traction (Honda Pilot, most DUVs) When I rotate, I take the rears and cross them to the front and then bring the fronts straight back to the rear. You can google most tire manufactures and they have recommendations on rotation pattern.
I got approx 40,000 miles on the OEM that came on my 2015 ML.
Also, you mention issue with cross rotating. Back in the old days when of radial tires first came out, Michelin did not recommend cross rotating due to the issue of messing up the steel bands in the tires. That is no longer the case and I am not aware of any manufacturer advising not to cross rotate.
But, as I mentioned on the first line, I don't think there is any incorrect pattern.
Old May 29, 2018 | 11:28 AM
scottiekay's Avatar
Thank you this info...
