W166 ML63 AMG rear brake pad chang
here is VIN 4JGDA7EB5EA311518
looking for instructions to change rotor and pad. also need tools specs such as torque for all bolts and screws. Thanks!
It is very easy. Search on YouTube for other AMG vehicles and follow the steps.
I did my own and it was like any other set of calipers, you just have to make sure you set the calipers in service mode in the computer menu.
16 E550 Cab, 2003 Ram bright red crewcab 4x4 we call Clifford :)
my notes from when i did it.....
Use 13 mm socket remove retaining bolt
push out pins with a punch
Pads should pull out easily... If not.. I used a flat blade screwdriver to gently push them into the caliper.
The rear pads require putting the car into pad service mode as described here:
1. Turn the ignition to Position 1.
2. Make sure the mileage is displayed in the dash center window
3. Don't wait very long before accomplishing the next step: Push the far right "telephone accept call" button on the steering wheel, then push the "OK" button on the left and hold both down for 5 seconds or so.
4. The workshop menu should appear.
5. Scroll down to "Pad replacement" and push OK.
6. Choose OK for "Moving to fitting position"
Read more: https://mbworld.org/forums/new-m-cla...#ixzz3JSpXdsvK
This will move the cylinder in the caliper far enough back to replace the pads...
wheel lug nut torque is 110 lbft
https://mbworld.org/forums/gl-class-...l#&gid=1&pid=2
li ma (01-28-2020)
