ML350- W166 trunk not working
Can anyone help me if they face the similar situation.
My 2013 ML 350 fell into category 3(b) this past spring. No rhyme or reason anyone could identify. I replaced the battery and the tailgate stopped working. Same beeping that you described. I recommend first check the fuses. If they’re good, you can test the lift motor by disconnecting it from the lift gate at the bottom and see if it runs using a small 12v solid state battery. If it runs, then take to a MB repair facility and ask them to run a firmware/software update. Shouldn’t cost more than $85. If that doesn’t fix the issue, replace the ECU. But beware - a new ECU is very expensive, and used ones (on eBay) are much cheaper but will probably then require a second visit to MB to run a firmware/software update that will enable the ECU to work with your system.
thank you so much I will follow the steps and will share my findings
