ML63 AMG (W166) 2011 -2015 (Replaced by GLE63)
ML63 transmission oil capacity ?
Old Aug 3, 2022 | 01:16 PM
threeMBs's Avatar
Only MBs - the best or nothing
When changing transmission oil, how many liters does it take - 7L or 9L?
Old Sep 15, 2022 | 03:21 PM
mcamp001's Avatar
2014 ML63 AMG
the answer is a bit more complicated than that. There is a procedure on here somewhere, do a search. The process involves filling through the drain hole and at a certain temperature the fluid will start to drip out. I started with about 5 quarts last time I did it, but a lot came out so it didn't use it all.
