Extended Warranty M157 Cylinder Head
I cleared codes both times, got car home safely and did the coil pack/plug swap in hopes of resolution. Will watch over next few weeks, but I imagine the hive mind would suggest leaving the code(s) next time and having car towed directly to dealer? ANY tips for best playing this game most appreciated
Next time your vehicle goes into limp mode and throws a cylinder 5 misfire code, I would get it to the dealer and insist that they do a compression and leak down test on cylinder five. This is the easiest and fastest way to diagnose the problem. They will probably suggest replacing the coil pack and injector before doing a compression and leak down test. Most likely this will not fix the problem and it will be a waste of your money and time. If the dealer will not do it, find a good independent MB shop and ask them if they have dealt with this problem and resolved it with the dealer.
I'll let you guys know the diag outcome evening most likely.
He'll start the job on Monday. Doing a few extra parts while the engine is out such as turbo lines, thermostat, pulleys & tenshioner, belt, motor mounts & trans.
Might add a water pump on top of it all. But my GLC loaner is just not cutting it.
I finished my leak down testing tonight, found VERY similar results!
cyl 1 = 9%
cyl 2 = 7%
cyl 3 = 20%
cyl 4 = 5%
cyl 5 = 70%
cyl 6 = 10%
cyl 7 = 10%
cyl 8 = 10%
So, I definitely have Bank 2 head issue, seemed like intake valve. Now I need an active CEL for misfire and will approach dealer
Send me your vin # and ill check to see if your vehicle has the extended coverage on the valves. The warranty is based on sell month of the vehicle, mine would be the end of March 2025 being a model year 2015, rr mileage up to 120,000k.
hopefully its not a canada based vehicle.
THANK YOU
I think Code P030085 needs to be present as a fault. (combustion misfiring is present on mutliple cylinders)
You also have an open service campaign for ECU update Emission Service Campaign 2022080005 Launch Notification Perform Engine Control Unit Software Update
Bummer re intake valve costing, thought that was covered. Still, significant coverage to resolve a 70% leaky cylinder is something. Of course it’s sad that it occurs at all in a 60k mi motor from a $100k+ vehicle.
If this was a customer pay job, I think it would be best to take the heads to a machine shop and see if upgraded valve seats can be done.
yeah I tried to argue with my Warranty Admin that I shouldn't have to pay for intake valves but i didn't get very far with her lol.
Hopefully you can get those codes to pop back up & crossing my fingas that it all goes well before you run out of Warranty
Keeping an eye on one of the hydraulic lines for a small leak.
Mercedes did pay my claim on my car within like 24 hours lol, so I took my old cylinder head home and might clean it up..
Warranty paid my brother i think 39.5 hours so he was stoked about that. Took 41 hours & that's with the accessory work he did.
question: once issue is fixed, how likely is this to recur on a different cylinder?
Matt,
I took it to MB dealer and they did a Xentry compression test that shows cylinder 5 low compression. I will PM you my VIN
What was the diagnosis for low compression on cylinder 5? What does the 20k repair bill fix?
