ML63 AMG (W166) 2011 -2015 (Replaced by GLE63)
Daytime Running Light (DRL) Replacement
Old Apr 29, 2025 | 06:05 PM
PeteyV's Avatar
W203 C230, W210 E350, W166 ML63
I searched this specific forum and can’t find any information.
My driver side DRL burned out today and am looking for work instructions on how to replace. I’m assuming remove wheel and inner fender liner but would like to know if there’s any short cuts not needing me to remove the wheel. I noticed in GL 550 the trim can be removed around the light but that is a different front fascia.
@chassis hoping you might be able to work your magic as usual with the work instructions I’m assuming I can use a trim tool to remove the trim around the DRL but need to make sure it’s not screwed it.
thanks in advance!
