Mobile Electronics and Lighting The archived forum for mobile electronics and lighting equipment for sale by members. Browse newer listings and create your own in our new Marketplace.
FS: Escort 9500CI and AntiLaser Priority Systems
Old 07-17-2016, 07:21 AM
jblaw's Avatar
C63
FS: Escort 9500CI Radar Detector and AntiLaser Priority Laser Jammer Systems
Ready to go Escort 9500CI radar detector / Antilaser Priority (ALP) jammer two sensor ultimate package for sale. 9500CI was just calibrated by Escort this July and a new plastic case was installed by the manufacturer -- with the protective film still on the front! Used for one year after original installation, but I just swapped cars and removed it.
Note: This is not just the ALP with the 9500CI radar sensor, but two complete and independent systems (without the 9500CI laser diffusers / sensors because they are rendered unnecessary by the ALP system).
As seen in pics, this includes the following:
Escort 9500CI
-Radar sensor just calibrated July 2016 with new housing installed;
- remote control / ECU / display / GPS, speaker, etc.;
- all necessary and included wiring, brackets and screws (though near in mind this is a used system, so one of the brackets for the radar sensor was bent to fit my last vehicle); and
- no 9500CI laser sensors / diffusers ( I got rid of them, per the advice of the radar and laser forum, because I was using the below ALP system in conjunction with this setup.
ALP Priority
- complete 2 sensor system originally purchased from BestRadarDetectors.Net;
- all included wiring and accessories; and
- unused metal brackets (I used 3M tape instead for installation).
This is being sold for $1,100 shipped within the USA. PayPal only.
Please bear in mind that is a used system, so there are a few minimal nicks and scratches, though everything works great and it was not on my car for very long.
Also -- this unit had been installed in my C63 -- check out the slick install photo -- you can do yours the same way!
Thanks!!!
Attached Thumbnails FS: Escort 9500CI and AntiLaser Priority Systems-image.jpeg
jblaw is offline
Old 07-17-2016, 07:27 AM
jblaw's Avatar
C63
jblaw is offline
Old 07-17-2016, 07:29 AM
jblaw's Avatar
C63
jblaw is offline
Old 07-17-2016, 10:52 AM
blaferty's Avatar
2015 C63S
any pics of the Escort unit in the car or ALP sensors mounted?
will ALP system accommodate additional sensors-I assume you only had two installed on the front of car?
blaferty is offline
Old 07-17-2016, 11:16 AM
jblaw's Avatar
C63
Hi Blacerty -- you can add three more sensors if you wish to the ALP system. They sell them at beatrsdardetectors.net. I had the unit mounted behind the front bumper, let me see if I can dig up some photos.
jblaw is offline
Old 07-17-2016, 11:23 AM
jblaw's Avatar
C63
These pics show the sensors for the ALP -- the escort was mounted behind the mesh lower grill inside the bumper.
jblaw is offline
Old 07-19-2016, 03:05 PM
Oilfieldtrash's Avatar
W215 CL55 (sold) Now C63
Cost for ALP alone?
Oilfieldtrash is offline
Old 07-19-2016, 03:15 PM
BEETS's Avatar
GLC 63
I'm a complete newb to radar detectors (if that's even what this is) but I've always considered getting a valentine one. I had no idea these systems can get this high in price, what's the difference?
BEETS is offline
Old 07-19-2016, 03:24 PM
jblaw's Avatar
C63
Hi @Oilfieldtrash -- At this point, I'd like to keep the ALP and Escort together for a single sale.
jblaw is offline
Old 07-19-2016, 03:27 PM
jblaw's Avatar
C63
Hi @Beets -- you will see hundreds, if not thousands of threads on the bulletin boards debating the merits of each radar detector. What makes this set up special -- and which the Valentine doesn't have -- is the laser jamming. It's a huge difference if laser operates in your area. This is also considered by most to be the best package bundle you can get for under $4k -- I did a lot of research before buying.
jblaw is offline
BEETS (07-19-2016)
Quick Reply: FS: Escort 9500CI and AntiLaser Priority Systems
